Having done automotive painting (I will not claim expert status in this area, just have done some over the years, and worked with ranges from laquer, now obsolete, to new two parts and base coat clear coat stuff), I would still go with an Awlgrip or Imron finish over the auto paints. Yes, Corvettes are fiberglass, and I've seen a few with spider cracks in the finish (granted they were older cars and didn't have the newest paints on them). And yes, we have plastic cars now and paints have changed, but the prep is the costliest part of a good paint job, so why go a different way than the boat painting industry to maybe save a couple hundred bucks when the real cost is all the prep work? Also, by the time you are working in gallon quantities and using additives, I think you will find that the cost savings is not that much - the right auto finishes aren't cheap either. I also do question the hardness factor - the boat is salt water blasted constantly, and I think this is where the hardness comes in. I am not going to say Awlgrip or Imron won't scratch or blemish when you hit your pier - they will, it's a film, and I've yet to see anything as durable as original gelcoat when it comes to a nasty impact or scrape. Chris also makes a very valid point, and that's market acceptance. Whether right or wrong, the next buyer might be scared off from a finish that is not considered "proper", whatever that may be. And for the record, I do have Awlgrip on Emerald, and have found that the Awlgrip products for caring for the finish work very well and are reasonable in cost. 5 years later, she looks like she was just painted, except for where I hit the pier once
And as Loren often points out, the above thoughts are worth what you paid for them....
-David
Independence 31
Emerald
