Below the Sole
ccorcoran
Athough the recent string about sole replacement was amazing in regards to the information provided, I have a question that would be most easily answered by those brave souls who have removed and replaced their soles (hey, you can't blame a guy for a bit of linguistic license!) on a late model E34. In particular, Bud from Escapade? Here's the Q -- there is a shower sump at the base of the gangway with a float switch and 350 - 500GPH pump. A 1.5 inch conduit enters from the bow of the boat and houses the wires for the pump and switch. From what I can tell, the conduit must make an abrupt 180 degree turn, heads under the floor pan in the head and emerge underneath the built-in (part of the TAFG) sink/counter inthe head; I'm assuming the wires string underneath and eventually connect to the auto/manual pump switch in the shower/head. Can anyone verify that this assumption is correct? The wires within the conduit have rotted and before I start trying to pull/push a snake through an abrupt 180 degree turn in less than perfect plastic conduit, I'd like to have an idea what I'm up against. Small matter, however, with all the talk about sole replacement, i was reminded that this problem is on the wife's "to do" list; something about creature comforts. Thanks!
