Since my last reply to Keith's thread, I got to thinking about this topic, and for those of you who use your boats infrequently, and/or store your boats for the off-season with the masts up, you have a problem in that your halyards are left exposed to the sun and wind-degrading all the time they are not being used..
The solution is what we do on the race boats EVERY Sunday when the boat is put away for the week: Keep a tag line for each halyard on board. When you are done sailing, be it for the day, week, or several weeks/months (depending on much you like your halyards-or how long you want them to last), simply attach the tag lines and pull them through until the halyard is down. Disconnect the halyard, rinse with fesh water(if in a salt water environment), coil, and stow below. If you have upgraded to higher quality halyards, this will protect your investment by a huge factor-you will double the life of the halyards, and have much higher confidence in them when they are in use.
In fact, some of you can even choose to re-run only the halyards you expect to need that day, keeping the spinn. halyard, for example, safe and dry if you have no plans to fly a kite. Of course you can always change your mind while sailing, as this can be done anytime, anywhere.
Some will do this every time they go out, some only for the off season, and some other will do it when they will be away from the boat for a few weeks.
However you do it-it is good for your gear, and also gives you chance to fully inspect them more frequently!
This only adds about 5-10 minutes to your pre-sailing preparation, and shows excellent seamanship and boat sense.
Love your boat and she will love you back!
Fair winds,
S
Fair winds,
S
