wurzner
If anyone out there has installed on of these heaters, I would appreciate information on what flew length was used and how low you placed it on the bulkhead. To get the factory specs, I need to mount if right above the cushions. I can remove the cushion when using it or mount it higher and have a stack above the deck. What I would likely do then is cap it right at the deck and install an addtional 2 ft section when using it and remove it when racing? Any comments or concerns with this approach? Any Photos?
Thanks in advance
:eek: shaun::eek:
Thanks in advance
:eek: shaun::eek:
