My '83 E28+ inboard diesel engine (original, but apparently serviced extensively a few years ago) started running very hot toward the end of the summer... getting up to 220 after only 10-20 minutes with little throttle... added antifreeze and it helped tremendously... the motor would run at 180-190 for a while at medium throttle, but then after a few hours would still get up to about 210...
Clearly there was some kind of leak or evaporation of the antifreeze over the course of the season... but still, the motor started running a little hot even on the day we added more antifreeze (but thankfully, not nearly as bad as it had been). I'd feel better if the motor could run all day at 180-190.
Any thoughts on how bad or unusual the problem is, what the problem may be, and what to do??
