gadangit
We have a crack on the keel along the centerline where the two halves were joined in a secondary bond. I know this has been a topic covered before and I have a fuzzy recall of one instance of a E39 having a similar split.
I have pretty much seen every square inch of hull on the inside and I've not seen any evidence of a crack from the inside. My guess is that the crack is in the filler and not in the actual glass, but we shall see. The crack really runs the length of the seam as you can see from the other picture. But there is old paint in there and it looks like it has been there for a while. The worst of the crack is in the left picture below on the leading edge of the keel. The right picture is looking straight up at the forefoot area.
I had a quick haul in October and I didn't see this, nor do I see any evidence in the pictures I took. We did have a tough regatta in November with 25-35kt winds which might have flexed the hull. It's the only thing that I can think of that may have caused the crack to form.
We'll grind it out and see what we find. Hopefully we can just clean it up and repair with a good fiberglass layup.
Wish me luck!
Chris
Wish me luck!
Chris
