    2024-2025 Fund Raising Info
Ericson 29 tiller wanted
CapnRob85
Looking for an E29 tiller. Online custom builders say it’s 1 7/8” width but my mount hardware looks like and measures 2”. Are they supposed to be a bit more narrow than the mount? Do you think it’s mandatory to use a drill press for the holes or can I just use a standard drill and vice? Do you recommend the epoxy finish or is varnish fine? I have a tiller cover from PO, so I’ll keep that on it. Any advice on where and how to purchase, and/or tillers for sale, please let me know!
gabriel
Live free or die hard
I had the same exact problem so I epoxied two pieces of wood on either side of tiller base then sanded to make it fit. I used an off-the-shelf West Marine tiller and a 5/8 quick release trailer hitch pin to keep it in place.
CapnRob85
Thanks for the feedback Gabriel. So instead of bolts and nuts you used trailer hitch pins, or you used the 5/8” quick release in another way? Did you actually adhere the wood to the tiller or more or less shimmed it?
gabriel
I believe my boat is a little different than your as I have a transom hung hung rudder but here are pics:
the wood I used to shim sits in the casting so can’t see it.
ps the pin was 1/2” not 5/8” don’t trust me or anyone for measurements!
Mine is indeed 1 7/8 and it is a snug fit. At some point in the past, somebody apparently cracked the bronze fitting trying to "make" something fit. Note that the new tiller I got from Ruddercraft was a bit shorter and lighter than the one that came to me with the boat. I'm still getting used to it.
CapnRob85
Thanks Toddster. I’m on a bit of a time crunch, as I am looking to complete a 35 nm transfer and my current tiller came apart last weekend while underway after I relaminated it with epoxy in an effort to recondition it, so it’s time to invest in a new. I am thinking I’ll try Gabriel’s method of shimming but I’m wondering whether that is going to be a problem long term and don’t want to buy two new tillers.
