Pretty much the whole history is in the Thelonious blog. Prospective owners of the model will find there a survey of typical maintenance projects.
Listing:
http://www.yachtworld.com/boats/198.../Marina-del-Rey/CA/United-States#.VktPBXarRD9
Thelonious was sailed singlehanded to and from Hawaii last summer. As a seasoned sailor, her owner was determined to create the finest Ericson 32-III currently on the water. Every aspect of the boat-- electrical, rigging, engine and safety gear--was brought to highest standards. He now intends to move on to a larger Ericson for further adventures.
If you want a perfect boat of this size for racing, cruising or heading over the horizon, you owe it to yourself to take a look at Thelonious.
Interior
The Ericson 32-III is known for extensive use of teak that goes far beyond the famous wine rack. The salon banquette can accommodate six guests at dinner. The navigation station is large and ergonomic. The bunks are skillfully integrated. The Ericson 32-III V-berth is largest in its class—6’6” wide at entry, permitting even athwartships napping. A dorade box and four opening portlights assure cross-ventilation. A wide quarterberth offers a large sixth bunk or easy storage for an inflatable dinghy. A gimballed propane stove and oven makes cooking under sail practical. This yacht has no leaks, as all ports, hatches and deck fittings have been replaced or re-bedded. Custom stereo speakers in salon and cockpit complete the ambience.
Sails/canvas
New UK Tape Drive Cruising mainsail, 3 reef points, 2013
New UK Tape Drive 135 genoa, foam luff, 2013
Ninety-percent crosscut jib, excellent condition
Sunbrella covers for mainsail, hatches, rails, winches, binnacle and whisker pole
Sunbrella cockpit shade, custom, 10’ x 10’.
Cockpit umbrella 8’, with binnacle mount.
Sunbrella weather cloths (nameplate removable)
Dedicated canvas storage locker
Engine
Universal M25 diesel, 1898 hours.
New Balmar 100a alternator
New Balmar AR-5 external regulator
Motorola 53a alternator (spare)
New Oberdorfer raw water pump
Starter motor rebuilt
New Facet electric fuel pump
Facet electric fuel pump (spare)
New 200-series Racor fuel filter assembly, 2014 (four spare filters)
New Teleflex cables for shift, throttle and kill, 2013
New engine heat exchanger, 2010
New heat exchanger, 2010
Dripless shaft seal
KnN diesel air filter
Electrical
Engine harness rebuilt, 2014
DC panel rebuilt, 2014
Cockpit engine panel rebuilt, all new instruments, 2014
New Victron battery monitor, 2014
Two new G27 105a flooded batteries, 2015
New Rule 1500 bilge pump, 2014
Rule 1500 bilge pump (spare)
Brass LED salon light, 2014
LED running lights, 2014
New Stereo, 2013
New Marinco shore power inlet
Xantrex 40a Truecharge 2 battery charger, 2010
New 50-foot dockside cord, 2010
Galvanic isolator, 2010
Navigation
New Garmin 50s GPSmap chartplotter/depthsounder, 2014
New Raymarine SPX-5 wheel pilot with p70 display, 2014
West Marine VFH radio with DSC, 2014
Ritchie Globemaster compass factory rebuild, 2014
Panel IPod/iPad charger, 2014
Rigging
Tides Sail track system, 2015
All new rope halyards, 2015
Spectra topping lift, 2015
New reef lines, 2015
New upper stay and turnbuckle, 2014
Jacklines with bolted anchors, 2014
Whisker pole stanchion mounts, 2014
New 4:1 outhaul with Harken blocks, 2013
New backstay and windex, 2010
Schaefer roller furling rebuilt, 2010
Rigging inspected and cleaned annually
Additional
All new rub rail, Taco polished aluminum, 2015
New 6-gallon WM-Kuma water heater, 2015
New Shureflow Flowmaster freshwater pump, 2015
New Teak and Holly sole, 2 coats CPES, 9 varnish, 2013
Custom boarding ladder steps
One-piece main hatchboard
Siphon break on bilge hose
Pedestal rebuilt with penetration welds
Four new Lewmar opening portlights
Fixed portlights removed and re-bedded
Main and forward hatches re-lensed
New salon table (original table retained)
New propane tank and regulator
New Whale Gusher Titan Ten manual bilge pump, 2010
Head entirely replumbed, 2010
Listing:
Interior
Sails/canvas
Engine
Dripless shaft seal
Electrical
New Stereo, 2013
Navigation
Rigging
Additional
