Rhett_m
Hello everyone,
I woke up to a considerable amount of water in my bilge this morning. I tracked it down to the bottom zerk fitting on my rudder post leaking. I had my boat hauled out this summer, and there was very little play in my rudder, and my steering has been smooth as butter. I elected not to drop my rudder, as I had other more pressing projects I was working on.
The water was dribbling out of my bottom zerk fitting. I decided to clean it with some wd40 and use the heat gun to loosen it up. I figured the ball was just stuck in the fitting.
I got my grease gun and put a tube and a half of grease in it. I imagine it was fairly low on grease. I plan on waiting until the next time I haul out to replace the zerk fitting witch is glassed in.
Im hoping with the grease, and I fitted a small piece of tube with a bolt plugging one end To prevent grease from escaping the non functioning zerk fitting. Any thoughts as to why there was water intrusion at the lower fitting? Does my remedy seem like a reasonable fix until the next haul out?
thanks everyone
thanks everyone
