gareth harris
I need to replace the main and jib halyards on a 42' mast, currently have wire/rope. Anyone any advice on this size of mast different from the discussion on the 27 below? Plus, is there a minimum thickness of line that will not tear up hands excesssively?
Also, any recommendations on material to use for spinnaker, staysail, topping lift halyards, which would be easy to modify for not having wire if necessary?
