Friction in the floor is a science.
Yesterday I put five layers of varnish on the cabin sole, but only part of it. To be able to walk, I divided the floor in three parts. Under the table, front cabin and main gangway. What I did was under the table and front cabin. The floor in the front cabin is tilting with a high angle, so friction on the floor there might be needed.</SPAN></SPAN>
After five layers of varnish, put wet on wet, I waited 30 minutes so it started to stiffen a little bit, then I sprinkled glass bits at 200-300 microns and waited till this morning before testing it. It gave friction all right, but it was almost too much. It felt like sandpaper. So tonight or tomorrow I will take the main part of the floor, and put on 40-70 microns. </SPAN></SPAN>
But on deck I really want friction when it is wet, so there 200-300 micron might be OK?</SPAN></SPAN>
I will wait till I have seen the result from the cabin first, and maybe I will try 70-110 micron on the deck. If it is too small I can always put a new layer with larger size glass, but it is difficult to go the other way.</SPAN></SPAN>
