One line solution
You need one line about twice the length of the boat plus lets say 10 feet. Any line will do if you have to go get some new line for this, then get something inexpensive, say 3 strand 1/4" poly propoline (It floats!).
When you are leaving the slipplace the line on the aft cleat on the side opposite that you want to turn to. The line goes around the stern cleat on the dock and back to the aft end of the boat, either a sheet winch or the same stern cleat.
As you back out the slightest bit of tension on the line will turn the boat toward the opposite side as the line is on. You let it run out around the cleat and back to the boatas you go along. Simple easy, when the boat is out of the slip, you drop the end of the line not on the stern cleat, and pull it completely around the cleat and aboard the boat. Even if you do not use floating line if you pull smartly you will find that it does not sink or foul the prop.
Guy
