FREE impeller
mherrcat
I have a new Globe #1130 (p/n 01-12-1790) Run-Dry impeller that I cannot use. Turns out it is the wrong size for my pump. Don't know if anyone can use this or not, but you can have it and a corresponding Sherwood #10077 impeller free for the cost of UPS ground shipping. (The plastic bag that the Globe impeller came in is opened, but it was never installed.)
The box for the Sherwood impeller is labeled "used spare" but it appears to have little or no wear.
Dimensions are:
2 1/4" Dia. x 3/4" Wide x 1/2" keyway shaft
What happened was I knew I wanted to replace my impeller and wanted to try the Globe Run-Dry. The Sherwood spare was on my boat so I assumed it was the correct part and ordered the corresponding Globe part.
Send an email if you want them.
