Gline
About 2 years ago I replaced the fresh water pump (coolant circulator) on my Universal 5432. I went with a new Kubota pump and provided paper gasket, from Kumar Bros. I used Permatex 22071 Water Pump and Thermostat Housing gasket maker. Worked great and pretty easy job. After about 12 months I noticed a little coolant leak, the seal between the two surfaces was failing. After 2 years I decided it was time to do it over again as the leak was significant.
I removed the pump yesterday and noticed the paper gasket was wet and mushy.
Did I do something wrong? Is there a better gasket or sealant?
I'm planning to clean the surfaces and repeat exactly what I did last time, but this seems crazy as it did not last.
