In the process of replacing fuel lines, lift pump, and primary filter assembly. Planning to install a “Y” after the secondary filter with shut off valves on the two outlets so that I can connect one side to the engine and one to the return line to the tank for purging air after filter changes. Question: can I simply add a “T” in the return line or do I need to add a valve between the “T”and the engine? Don’t want to put modest pressure on the fuel thingies on the engine if that would be a bad thing.
