Re: Removing fiberglass pan to gain better access to bilge...
I have a 1976 E39 with a fiberglass pan floor for the cabin sole, covered over with teak&holly ply. My question to anyone is have you ever cut open your fiberglass pan so as to get better access to the bilge area? Right now, the only accesses to the bilge Ericson built-in (at least on my boat) were 3 access openings, 10"x10" each. On many of the newer boats I've been on (mostly European designs), the cabin floor is made up of plates of wood resting on struts that can be easily lifted for access to the hull components below.
Cleanliness reasons aside, I need to be able to inspect (and possibly remove) the water tank that is underneath, and also there are a couple of ferrous steel struts that obviously will need occasional painting or they will rust. I can barely get at these right now from the tiny factory access openings.
Has anyone out there ever performed a "floor pan-ectomy?" If so, what things should I keep in mind? Will removing all or part of the floor pan impact the structural integrity? Cause other problems?
As I research this further I'll post my findings and/or pictures.
Thanks!
Thanks!
