ron7546
Hi Helpful Sailors,
Halyard (main) question ? ? ? E27 new to us this year and I have struggled with the task of hoisting the main tight enough.The halyard runs down the mast (exterior) and then thru a center opening in a mast mounted cleat.No winch and no block.Two people forward can do a fair job but this should not be necessary nor should a winch be needed.I don`t think.
My thoughts- - - a cheek block on the mast or a standup block on deck should give me a 2:1 purchase. I`ll tell you,I get goose bumps each time I drill into the mast.Just rewired the stick with 5 conductor cable( at $ 4.00 / ft.
Your Thoughts Please ? ? ? ?
Thank You
Ron
Thank You
Ron
