Hello All - Here's the background:
Just bought the boat. Picked it up from the broker's dock and motored about 30 mins to my marina. No odd sounds, shifted and ran smoothly in both forward and reverse. While docking (for the first time with this boat) I inadvertently shifted from reverse, thru neutral, into forward without reducing throttle. Not good, but didn't notice or hear anything unusual in the process - other than my beating heart when the boat lurched forward...
For the past 4 weeks, I've removed and replaced most of the wet exhaust system (heat exchanger, manifold, elbow, hoses, etc), so have not started the engine again since that docking episode. I got it all back together yesterday. Started the engine - no leaks, purrs like a kitten.
I've had this nagging concern in the back of my mind, so at low idle I shifted into reverse just to ease my mind. There was immediately this very loud banging that shook the whole boat violently. I quickly shifted back to neutral and it stopped - the engine purring away as usual. It's a Yanmar 3QM30F with the Kanzaki Transmission.
I suspect my little docking stunt damaged something in the transmission or shaft connections, but not sure where to begin with my process of elimination to find the problem. Does anyone know from this description what I should check first? Obviously, I'm now a little worried my next project will be having a new transmission installed!! Any help would be much appreciated.
Thanks!
John
Thanks!
John
