Hi, does anybody know the color of the blue waterline on 34 Ericson’s 1990? I am looking to paint the gel coat waterline.
If no one knows, and given that it's probably faded alot, you might try picking up a bunch of blue color samples from a paint store and choose the closest match, or the color you prefer. They can also advise on what paint might last on the water line, given the heavy wear there.
splinskey
Thank you so much! they are sending me color charts from interlock Toplac that they recommended for the blue waterline. I was just thinking maybe someone would know best product and what color matches the best but I guess I will have to use the samples to figure it out. Thanks for replying.
Slick470
I just re-did the cove stripe on our 1990 Ericson/Olson911. It is a very dark blue. I used this company https://www.vinylstriping.com/ and requested samples of their blues to try to color match. Closest they had was in the Avery Supercast line in the "dark blue 1019"
Several years ago I went to Home Depot and grabbed a bunch of Behr paint color cards and thought "570F-7 Midnight Dream" was probably the closest. I used that comparison to get a friend with a vinyl cutter to do new name and hailing port graphics to make us new to match.
Hopefully that is helpful.
splinskey
How did that work? Was it tough to bend the vinyl around the waterline? Did you need to cut it because different sizes could be in the mix? Thanks for the info. I was actually thinking of painting it on but this might be another avenue.
My 32-200 was Interlux "Arista Blue". Seems like painting is just too easy compared with other options. Also, I think spraying is a waste of effort with the new paints that roll and tip so nicely.
Slick470
I did the cove stripe which is the one higher up closer to the deck so a lot less of a challenge to install than the boot stripe at the waterline. I'm sure it's possible to do the boot stripe with vinyl but I agree it would be more challenging to do. Our boot stripe is gelcoat and it does oxidize after a couple years, but a decent round with a polisher it is good until the next time.
JSM
Redid the lines on our 34-2 when we got the boat 9yrs ago they were faded and in pretty bad shape. I used Interlux Brightside flag blue. Still looks great.
Last year I painted my stern with Pettit EZpoxy two part and was really pleased with the outcome.
