Wood, Interior Homestead Marine Plywood
Includes wood work and finishes including all interior, cabin sole and others (excludes exterior brightwork).
L
Leslie Newman
Guest
For wood, the best place I have found is Boulter Plywood. Shipping prices are incredibly low.
I bought all my lumber and plywood here for the latest dinghy I am building.
http://www.boulterplywood.com/
Before I found Boulter Plywood, I purchased teak and Holly from Homestead to redo the cabin sole in our CAL. Very good people to work with, but shipping cost was much, much higher.
https://www.marine-plywood.us/teakandholly.htm
If you are doing any NMEA 2000 stuff, I have found good prices on Amazon. The 'Lowrance NMEA 2000 starter kit' is plug compatible with Garmin cables, so you can use this kit for the backbone and spur runs. I also took the backbone cable from this kit and spliced the end of the Raymarine Seatalk backbone cable onto one end when I was installing the EV-100 very far from the other equipment. Needed a long run of backbone cable and Seatalk cables are expensive. Seatalk-ng is proprietary, so doesn't mate with other cables unless you purchase adapters, or make your own by splicing the wires.
