Really need to be sure this engine is seized. I honestly don't understand what you mean by seized due to compression, unless you have hydrolock going on. Engines seize due to lack of oil, spun bearings etc. Low compression could result in lots of blow by, but seized due to compression, like not turning over, doesn't make sense, unless you're full of water in the cylinders.
Do you have the hand crank that goes into the front of the flywheel? Regardless, pull the spark plugs, and see if you can turn it by hand. If you don't have the hand crank, pull the starter and using a large screw driver, carefully (don't break a tooth or the end of the screwdriver) see if you can move the flywheel by turning it via the now exposed teeth on the ring gear.
If the rings have become stuck on this engine, buy some Marvel Mystery oil, and put an ounce or so into each cylinder, and let it sit a few days, and then see if you can get the engine turning over. Sometimes stuck rings can be worked free.
Any detail of how it was running and stopped running would be helpful. Did water get sucked back into this from over cranking trying to get it started, and then it wouldn't turn over?
