Isabel
RicoPaolino
Does anyone have recomendations for tying up an E 27 at a marina.
Double lines, Cleats seems too small, Where to tie up at pilings for tidal surge?
Thanks for the info.......
Geoff Johnson
Fellow Ericson Owner
My boat's is on a mooring and depending on how close Isabel gets to Long Island Sound, I have been thinking of running lines from my bow cleats to the primary winches to relieve some of the expected strain.
RicoPaolino
Good luck Goeff
I think anywhere up in the northeast will be pretty rough.
I'm in the northern cheasapeake.
I was trying to get info on how to tie up at a dock properly. I think there will be a pretty good surge.
I want to get as much vertical motion and not too much side to side. I was thinking about a longer dock line like a longer anchor line may give more stability. ( I don't know really but is sounds good ). And with 1/2 inch line I don't have much room on the cleats on the e 27 to put a double line.
RicoPaolino
Thanks Geoff!!
You write:
The current maps have the storm headed right for the Chesapeake so you are going to have a hellava storm surge, I would guess.
-----Oh boy no kidding!!!!! :esad:
The diagrams on nboat were just what I was looking for!
I'm going tonight to the local Home Depot to get about 300 ft of 1/2 nylon line. And tomorrow I'm going to strip the stuff and tie up.
Thanks again!!
Sean Engle
Your Friendly Administrator
Administrator
Founder
One other thing...
I would strongly reccommend you add those heavy rubber snubbers to your primary lines to reduce the shock for your cleats/tie points during gusts.
We get really nasty wind storms here each fall (winds topping out around 60-90mph) and I always had to tie things down tight - putting on those rubber snubbers made a hell of a difference!
Good luck to those of you in her path! :)
//sse
