Stuart 28-2
This is an impeller pump. Model 18660-0123. It is installed on my boat as the bilge pump.
When I bought the boat a few months ago it was tripping the breaker within a few seconds of turning it on. I eventually found the cause to be the cover plate was jamming on the impeller causing it to struggle to rotate and even stall. There's not a lot there that could cause this.
The o-ring width looked way too small for the o-ring groove. That would cause it. So, I found and bought a larger o-ring and installed it. Problem solved, no more breaker trips. Bucket test off boat shows it pumping water just fine. I did not check flow rate but I'm going to asap.
Anyone know anything about this, heard of it before with this pump?
