therapidone
I have a hand-held GPS so having relatively accurate speed readings (over the ground, anyhow, and that's the only measure that truly measures progress) isn't a problem. However, my knot meter is so much out of kilter in its readings than the GPS as to make me wonder why pull the plug from the through hull & put the transponder in when we start every sail.
Yesterday, in very good winds for the Chesapeake in August (in fact, this has been an excellent summer for sailing on the Chesapeake...with our sailing days pretty much limited to weekends, we've had some outstanding sailing conditions all summer long) at 16 - 18 knots & our mainsail reefed at the first reefing point & at the time only about 1/2 the area of our 135% genoa unfurled, we were making 5.8 - 6.3 knots close-hulled (depending upon the size of the waves hitting us) according to the GPS, but according to the knot meter, we were between 7.2 & 8.2 (what a bunch of hooey--I can understand knot meter readings in excess of 6.8 knots if we are surfing, but w/ a 25' 4" LWL that is probably reduced a great deal when heeled over at 20+ degrees, readings of over 6.7 or 6.8 knots when close-hulled just don't make sense, do they? )! Yet, at other times--especially in lighter winds, the GPS and knot meter are surprisingly close.
What would I need to do to determine just how out of touch with reality the knot meter is?
How would I go about fixing it once I have determined the gap from the "fantasy world" of the knot meter and what would be a much more accurate measurement?
Regards,
Ed
Regards,
Ed
