    Adventures & Follies
    November Meeting Info
Lifeline Netting
RKCRWLR
Putting netting on Goin' Rogue. Top line is 22 off the deck. Choices are 18 or 24 inch netting. Does it matter which one? Also, looking at Sea Mar sports netting in Seattle to supply it. Anyone using their netting? Thanks! -Tim
exoduse35
use the 24' it will just take a bit more pull to draw tight if you have a single line. If you have dual lifelines the 18" are perfect to run between the two. Also ou will need to un a second line through the base supports to keep the bottom secure.
