D
desierto
Guest
Hi,
I am a prospective buyer of an Ericson 34t and I find considerable less information in these pages than there is for other models.
Besides, what I've seen doesn't sound too good: one boat dismasting, another one pulling the chainplates...
Is the construction of this boat less robust than other Ericsons?
I see that the boat is nearly the same dimension as the 35II but 1000Lb lighter while the ballast weight is the same and the keel deeper. 35's are reputed (in this forum) to be quite tender. From those numbers the 34 should be less tender. Any experiences?
It sounds like undersized rudders is a common problem to E32's and E35's. What about the E34t? I also read quotes from $600 to $7000 for enlarging the rudder..., quite a difference! Any comments?
Thanks a lot.
Alejandro
Thanks a lot.
Alejandro
