sailorman37
I didn't like the idiot light set-up on the Universal 5416 when I became the new owner of a 30+ so I took out the sender and fitted in a proper adapter and oil pressure transmitter. To my shock, after fitting up the transmitter, the oil pressure reads about 1 lb or at most 2 lbs, even at high rpms. Not believing the results, since the engine doesn't smoke and it seems to run fine, I took out the transmitter and attached it to a known air pressure to which the transmitter and gauge tested out OK. So, I really have basically zero oil pressure at the end of the oil passage where the transmitter is fitted.
(The idiot light never lit since I found it was burned out.)
My thoughts are the oil pick up is clogged, the oil pump is bad, or the bearings are horribly worn.
Option 1 or 2 seems most reasonable since the engine runs fine without smoking. Also, dumping in high viscosity Lucas Oil didn't increase the pressure. I also fitted in a new relief spring and ball without any change in pressure.
Regarding option 1. Looking at the diagrams, I am not sure if I can easily disassemble the oil pump in place. Does anyone know If that is possible?
Option 2. Is there a way to blow air back down the intake pipe to the sump to clear out any debris?
Any other ideas would be appreciated.
