    2024-2025 Fund Raising Info
mmmm,cant get no water out of my tabs(e29)
timoteo
:egrin:
well dear peoples , if someone out there can help me with some advice about the tabs and or watersystem on my e29, i did fix it so far that it already spits some water , but realy like a lil' steady flow, :confused:
ref_123
Check the lines
Hi, there,
looks like either air getting somewhere in the line or a bad pump. I would first check the pump, because it is less hassle and old pumps are known to have issues. In my case, the air was actually leaking through the screw-on strainer.
Test the pump directly with a bucket of water - put one end of the piece of the hose in the bucket, and the other on the intake barb (may have to have a fitting for that) of the pump. If the flow is steady - well, partner, you are in for some fun with lines. Loren had a lot of information in earlier threads on thsi subject.
Good luck!
Stanly
