Aloha!
I am replacing my Atwood 6 gal water heater with brand new one. I would like to be able to move the heater over to port from its original position, to give a bit more working space on the starboard side (where I seem to spend most of my time). The shifter and throttle cables go through, then underneath, the plywood flooring.
I have seen posts about replacing the old cables and rerouting them, and/or changing the length.
Is there any reason that I should not change the position/location/routing of these cables?
Another semi-related issue regarding the shifter cable, when I go into forward gear (a couple of resistant inches for the handle) the lever at the transmission appears to move as far forward as it should and can go. When I go into reverse, the handle smoothly moves well back to probably a 70 degree angle from straight up (it can actually interfere with the steering wheel) although it engages into gear well before that.
Is it time for a new cable? Is this a routing issue to begin with, as you can see in the picture how the cable takes a fairly serious bend when it goes down through the floorboard and curves back around?
Thanks for any help and advice!
Eric
1988 32-3
Liliana
Eric
1988 32-3
Liliana
