Fred Dentinger
I’m doing a refit on my 79 Ericson 30. Thruhulls, shaft, packing box, engine rebuild, headliner & cabin siding, cushions, perhaps some portlights. I must be nuts doing it all at once.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old shaft was gouged/worn pretty bad at the gland & worn at the cutlass bearing. Packing box was pretty crusty. Thought about going to a PSS dripless, but the access is so poor, decided to stay with what I know how to do – packing adjust is pretty easy & thought I would try some of the dripless mouldable packing. Had new shaft and half coupling made up. Bought a new Buck Algonquin packing box & installed it. Started to slide the shaft in…… clunk!
<o></o>
The packing nut bore is fine but the box bore is tighter & will not fit. Anyone run into this before? Should I return it, hone it with a brake cylinder hone, take it to a machine shop and have it bored? Suggestions welcome!
<o></o>
Fred Dentinger fdentin@comcast.net
<o></o>
<o></o>
