I'm looking at the alternatives on where to install the radome, and the chartplotter/radar display, on an E32-200. On this boat it looks like the steering pedestal is the only feasible and useful place for the display. So cable has to get there, either from the stern, or up on the mast. Running cable to that location from the mast raises issues of messing up the headliner and possibly having to cut and splice the cable to cover that much distance. A stern pole mount is easier in that respect, but may be considerably more expensive-- just because the pole etc is pricey.
Although I'm leaning toward a stern pole mount, I'm wondering if running the cable inside the headliner is actually the only way to route the cable when the radome is on the mast. I could do a mast mount and avoid messing with the headliner if the radar cable were routed under the cabin sole, aft to a point under the pedestal. This would involve drilling sizeable holes through the fiberglass substructure of the boat, from near the mast base, going aft. It doesn't seem like a foregone conclusion that running cable through the bilge, and drilling these holes in the glass longitudinally from the mast base to a point under the pedestal, is O.K. Do any of you have any opinions about going with a mast mount and routing the cable this way? Thanks for your help.
