I have the common arrangement of a foot-operated fresh water pump serving a dedicated outlet at the galley sink, along with an electric pressure pump which serves the house plumbing including a conventional faucet set in the galley as well as one in the head. When using water in the usual way from the pressure pump, there is always flow from the foot pump outlet in the galley.
The electric pump is a Shurflow Aqua King II, which is a pulsing type pump. The foot pump is a Whale Gusher Galley. Both foot pump and electric pump draw from the tank manifold, as they should.
I think my plumbing arrangement is pretty common, but I would like to think there is a good solution for reducing or eliminating the waste of fresh water from the foot pump outlet as a result of pressure pulsation from the electric pump. For example, is it common to have a check valve before the pressure pump?
Any thoughts?
Any thoughts?
