Jim Picerno
1989 38-200
My new boat is on the hard in CT, and I’ve just booked a launch date for the first week in May. Consequently, I’m thinking about some pre-launch items.
- My current plan for the boat is to leave it in CT for the summer, then sail it home to FL late in the fall. The current anti-foul paint is Micron CSC. I’d like a paint that’s suitable for the Northeast, as well as Florida, and if possible last two years. Easiest path would be to stay with Micron CSC. Or should I consider another ablative with more anti-foul properties? Pettit Odyssey Triton looks interesting and is compatible for painting over Micron CSC.
- I’ve got some 6” – 8” cracks between the keel stub and the keel (see below). If there’s no weeping I’m inclined to applying fairing compound, sand and paint. Though maybe a better plan would be to widen the cracks with a Dremel, fill with 5200 or G-flex, then apply fairing compound over the top.
- My previous boat had an encapsulated keel, so keel bolts are new to me. According to my user manual, my boat has four 1” bolts, and eight ¾” bolts. I’ve tried to go through all the threads on this topic, and I’ve found one or two references stating that the 1” bolts should be torqued to 175 – 200 ft lbs. Of course, all the torque tables I’ve found online have a much higher torque rating for a 1” inch bolt. I could find no references to the torque settings for the ¾” bolts. It seems like a better idea to tighten these bolts while the boat is on the hard but maybe I shouldn’t mess with them at all. As the redoubtable Mr. Williams has said, he’s never heard of an Ericson losing a keel.
