Captain Crunch
Hello, On my E-35 all the halyards are raised from the mast. I don't think the mast is stock. Tall rig I think. The winches and cleats are mounted on it. I would like to run all the lines aft to the cockpit. Except for the headsail uphaul. There is already a crappy small spinnaker winch (I currently don't own a Spin.) on the starboard side that I would like to move to the port side and use for one of the reefing lines and maybe the topping lift. Then I would like to take the winch off the mast and mount it on the starboard side for the main uphaul, another reefing line,and outhaul. All with the appropriate roller blocks and cam blocks (hope this is the right terminalogy). Which finally brings me to drilling through the deck and using maybe teak backing plates to mount all the hardware. I would like to know if there is any special considerations for this procedure. Tricks? Washer size? Sealents? Thanks for any info.
