I have removed the sea hood for re-bedding and other work, and I would like to remove the traveler track from the sea hood. I assume the track is original. I rented an impact wrench for removal of the seven Phillips head bolts, but have managed to remove only four while the other three will no budge. I tried PB Blaster and a bit of heat. I have broken two bits, with no further progress. Any thoughts on how I might be able to get this done without destroying either track or hood?
