Andy Rogers
Hi.
In the diesel survey I commissioned as part of the buying process the mechanic noted that the propeller seem overwheeled. The max RPM achievable under load was 2100 RPM on the Universal 1984 M-40. I have found that I typically cruise around 1500-1600 RPM.
The mechanic suggested getting the prop repitched to bring the engine up to normal cruising RPM (2000-2500) to avoid carbon buildup in the engine and to be able to achieve max horsepower when it's needed.
Any suggestions, warnings, or thoughts on the repitching process. I'm about to ship my prop off for a quote and I'm guessing I'll be hit up for around $200-250.
Andy
Andy
