We are hauled out for bottom paint and a couple of other things, but I have run into a complication.
The E31’s rudder’s leading edge, below the waterline, partially resides in a concave indentation in the hull. This means I can’t remove old paint or apply new to that area, of the leading edge of the rudder, without removing the rudder. The complication is the steering quadrant passes through a small opening in the transom. It’s the middle pintle looking piece in the photo. The quadrant looks to be too wide to pass back out through that opening.
I’ve found some threads on 31I and 36C rudder clunk, and think I understand the basics of removing it. But, for E31 or E36C owners that have removed theirs, any tricks or tips before I disconnect the quadrant from the rudder and then remove the rudder? Can the quadrant remain attached to the steering cables or is it better to remove them?
