jon newman
After removing all the through deck connections { u-bolts}I found that the rust had started to attach the threads at the very top where the deck seal is located, just about 1/2 inch into yhe deck. this is classic crevice corrosion, oxygen starviation. Al;though this was cosmetic, the metal was pitted.
I wish we all could afford Hastalloy C or 256Mo, hardware, i just cleaned and passivated the threads and re-bedded, I treated the blocks , rod and fastners with Anti - ox, compound. The trick is to tape the threaded end before you push them through.
Note the hole size for these fittings was 1.5 times bigger than the bolts, when you clean out all the old sealant, make sure you use alot of 101, and get some into the holes.
