We have an S2 propane sniffer on our E30+ which must be turned "on" after the propane valve is opened, and the stove button on the panel is turned on, in order to get propane to the stove/oven. It has a green light to indicate when it is on.
During a recent sailing trip, after going through the steps listed above, the green light didn't come on. However, the red test lights beside the green light did light up and the alarm sounded and the mute button turned off the alarm. We did have propane at the stove, and it all worked normally.
I took apart the propane sniffer, hoping to replace the light bulb and discovered the small LED light inside (it looked like the back of an older transister radio, with no serviceable parts). I then checked all the wiring connections for the sniffer, and they all seemed tight--and still no green "on" light, though it continued to work as normal.
I tried to contact the company for advice/parts, but their phone is out of service, so I'm assuming they are long gone.
A couple of days after we resigned ourselves to using the system without an "on" light, the light reappeared, only to go out a few minutes later. And next day, the light came on again and stayed on until we turned it off several hours later.
I would appreciate any thoughts/advice on why this may be happening, and any suggestions for a remedy. I love that it's on again, but would like to understand why this problem occured, and what I can do about it if it reoccurs.
Frank.
Frank.
