Starter Motor wiring
dpbishop
Ericson 35 Mark II, Yanmar 3YM30: Replaced the starter motor, can't figure out the wiring. The solenoid has two threaded post & 1 spade fitting. Cables to connect: 1 power cable, 1 cable from starter & 2 red wires from cable harness with circle connectors.
Does this help? Wiring diagram, color codes and legend are on pages 92-94 of that Operation Manual. Typically, the solenoid will get power (12V+ and maybe ground) and starter motor will get large cable power and is commonly grounded to the engine through the mounting bolts.
southofvictor
Trying to see if I have a helpful pic. Here are my best so far:
It‘s an old photo because I‘ve changed my start battery config so I can’t look at my current setup.
Starter switch goes to spade terminal. Large post gets battery + and alternator +.
