On our 1989 E34 Universal M25XP with 1260 hours on it, we noticed a steamy exhaust and higher running temperatures when cruising at 2300 plus rpm. I did the usual - change raw water pump impeller, clean out raw sea water strainer, check sea water flow, nothing helped. When we last arrived at the boat on a Saturday night prior to a two week cruise in the San Juan's, I decided to take out the heat exchanger to see what it could tell me. When I took off the end caps I got my answer. Bingo!! The raw water intake side channels the water through one quarter of the tubes in the exchanger. They return to the outlet side by running through the other three quarter of the tubes. In doing so, they cool the engine coolant that runs through the exchanger on the outside of these raw water tubes.
Of the ten or so one quarter inch tubes on the inlet side, I could see daylight through one. The others were all plugged with calcified 'critter' remnants. So, what do you do on a Saturday night?? Rad shops are closed, Sunday too. So I very carefully scraped off the debris and used a small wood dowel and a carefully filed round end of a clothes hanger (did not want to scratch or scar the inside of the bronze tubes) to clean out the tubes. I then put end caps on and filled the sea water part of the exchanger with vinegar and left it to soak overnight. Next morning I rinsed the unit, installed it and put on all new hoses and clamps, filled the cooling system with new antifreeze mixture, started her up and watched in absolute amazement the amount of water now coming out of the exhaust. I then cleared the infamous M25XP airlock - on mine always found in the hose returning coolant from the heat exchanger to the engine coolant pump, in that ninety degree elbow hose going into the bottom of the pump.
The engine then ran at 135 degrees F at idle and 165 at hours and hours of cruising rpm. Sweet.
I now need to add a stainless mesh screen into the raw water stainer. I have the stainless cylinder with the one eighth inch holes in it. The critters are getting sucked in through that. In our marina we have these critters about one inch long, one sixteenth inch thick with an exoskeleton - almost like a miniature crab leg. They always lock up my speed transducer's impeller if we don't move the boat for an extended period of time. I now know they do other things too.
The heat exchanger will now be serviced every three to four years - but by rad shop on a planned maintenance basis. We finally left on our vacation and had a wonderful, windy two weeks.
