Hi,
I would appreciate any insights or help on a puzzling corrosion problem on my E30+ Yacht Specialties steering pedestal. The part of the pedestal that holds my speed/depth instruments sits on two 1" stainless steel tubes (sorry, don't know how to post a pic). The part in question is made of aluminum, and is attached to the stainless steel support tubes with two stainless screws embedded in the aluminum so that they cannot easily be removed.
About every two months, without any advance notice, a small crack and slight paint blistering appears in the bottom two inches of the top piece that rests on the stainless supports--it seems to happen overnight! At first I thought it might be from me leaning on the pedestal for support, but I have been very careful to avoid doing that, and the problem has reoccured.
I have chiselled/drilled out the crack and filled the 1/8" by 2" crack with Marine Tex, sanded and repainted, quite successfully, only to have the problem reoccur.
The insulated electrical wires for the instruments are routed up the inside of the stainless steel support tubes--I don't know if electrical current inside the tube would increase corrosion or if that is irrelevant. But the problem is much worse on the side containing the electrical wires, almost non-existent on the other side (just very minor paint flaking and no cracking).
The only permanent solution I can think of is to try to drill out the embedded screws, remove the top aluminum piece, coat the inside where it sits on the stainless tubes with dielectric grease and reattach with new stainless steel screws, also coated with dielectric grease.
Does this all make sense? Has anyone else encountered this problem? Could there be a different cause to this problem, and hence a different solution?
Thanks for any tips, insights or advice.
