Check the clamp that holds the engine end of the cable housing. It can loosen up and allow the housing to move which will limit the cable's effect. On my 28 the clamp and a portion of the mounting bracket were missing due to corrosion and the cable was wired in place. I had to remove the bracket clean it up and braze a new piece of metal in place and install a new clamp. It also may be that the cable itself is beginning to destruct. Also check the set screw that hold the shifting lever to the transmission. I believe that it is keyed and probably not the problem but worth a check anyway.
If the transmission shifts normally by direct operation of the shift lever, just replace the old Morse/Teleflex cable.
Old cables can't really be lubed anyhow, and the butter-smooth shifting of a new cable is well worth the $50 or so.
Not sure about the 27, but on my boat the access is: compass comes off, some machine screws come out, and the linkage assembly can be pulled up six or eight inches (using slack in the throttle and shift cables).
Lately I have noticed that I have to pull all the way down on reverse gear shift handle in order for gear to engage, is there an linkage adjustment? could it be possible cable is stretched? any suggestions would be appreciated.
Thank you
When I still had my A-4 in our '73 E-32 I had a similar problem (Now have a diesel). If you have the old A-4 manual, there is a section explaining how to adjust the gear and reverse engagement inside the transmission box itself.
I did this (many years ago but have since forgotten exactly what I did). ...I do remember the top cover came off (4 screws) and I was able to fine tune it in spite of standing on my ear to get at it all. It took a little playing, getting greasy, climbing in and out to test it - but - once adjusted, I never had the problem again.
Also, when I took delivery of the boat brand new, pulling it into reverse was very very difficult. Turns out the cable was pinched and kinked from the factory installation. After "kissing' the dock a couple of times, I on my own then traced the cable and found the problem. A new cable and all was well. There were a few other problems with her but once corrected - she's been a dream! I will admit a couple times I got almost frustrated enough to rename the boat "Sum Ting Wong"!!
-good luck with your problem! - kerry
thank you Kerry, I have not found the book yet. But next week I can stand on my ear and have a look! :0
You're welcome.
Sorry I don't have my old manual anymore that I could send you - BUT - I did go online and found a site with a PDF of the old manual.
You can check the complete manual out at this site:
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <wunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--> Universal Atomic Four Manual - PDF ( http://www.manualslib.com/manual/615712/Westerbeke-Atomic-4.html?page=66#manual )
<!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> In particular to learn more and solve your specific problems, check out pages 52 through 54 and especially look at page 66.
Fair Winds!
-kerry
thank you!
