Looking at the exhaust on my 5432 last weekend it occurred to me that it could be improved. The exhaust exits the riser to a hose that is tapered and clamps to a 90* bronze plumbing fitting then to the waterlift muffler. The 90* fitting is a standard marine plumbing fitting with screw in hose barbs, etc. This fitting, assuming it is like every other fitting I have ever seen, will be quite restrictive to exhaust flow with the multiple interior convolutions and the harsh 90* turn. I am wondering if a heavy wall stainless steel mandrel bent 90* elbow could be substituted at this point? In theory, this would improve flow, should decrease backpressure, etc. This should allow the engine to make slightly more power at a given throttle setting due to decreased pumping losses, run cooler, and produce less soot. Any ideas/input on this one? Or do I have to be the guinea pig? RT
