Hi All,
I have a question about my oil level on the dipstick of my M35A diesel. After changing the oil with one of those suction pumps, I refilled the engine & checked the dipstick. I know you can't always get all of the oil out with these suction devices so it's hard to estimate how much oil is left in the engine when refilling with new oil. Anyway, after the oil change, I filled with new oil & the oil level on the dipstick was at the top mark so I thought this should be good. After starting the engine & running, then letting it sit for 5 minutes, the oil level reads full.
Here's my dilemma - the next day when I go down to the boat to check the oil before starting up, I check the oil & it reads just at the bottom mark (ie add one quart). So I wipe the stick & immediately put it back in to take another measurement - it reads on the full line. Bear in mind I have not started the engine at all at this point.
So in a nutshell - the first reading of the day reads low, and every subsequent reading reads the correct oil level - all with a cold unstarted engine.
Have you heard of this before and if so, which is the correct reading? When running, the oil pressure comes up to 50 psi right away & the oil warning buzzer stops very quickly after engine start.
Many thanks for your reply.
Steve Gabbott
E35/3 Silent Dancer
Vancouver, BC
Steve Gabbott
E35/3 Silent Dancer
Vancouver, BC
