I have a 1983 E28+ equipped with a Universal M-15 diesel that insists on running hotter than spec (which is 150 degrees). The engine is set up with a closed coolant system rather than use raw seawater for direct cooling. Would this "modification" cause the engine to run hotter (say 175 degrees) that the version cooled by seawater alone? I had the impellers replaced and the cooling lines of the closed system cleaned but it made little difference. Water seems to squirt out the exhaust port ok. Do I need to add this to my list of things to worry about?
Gary G
s/v Imi Loa (E 28+)
Gary G
s/v Imi Loa (E 28+)
