refined question on v-drive
thanks for the reply Guy,
OK, I'm wondering where in the sequence I run raw water hoses to the v-drive. The manual says to run the raw water to the transmission cooler after the sea strainer then to the pump, then to the oil cooler then the heat exchanger and finally into the exhaust elbow and over board. The system now seems to follow this sequence well, all the coolers are in line with very little bends and turns. The v-drive is about three feet forward of the transmission.
