Fully Restored 1984 Ericson 30+ Nomad $27,500 Portland, OR
Posting this to the Ericson forum before listing with broker or other platforms. This beautiful Ericson 30+ is turnkey and ready to sail. Dry boat. Much attention has been given to finding and stopping leaks and water ingress. No musty smells, no mold or mildew, no gross bilges. Nomad is sailed frequently and every system has been diligently gone over and repaired, restored or upgraded with high quality equipment and materials since 2018, no shortcuts or quick fixes. She is easy to handle and set up for single-handing with all lines lead aft. One can easily reef the mainsail in under a minute. She sails beautifully and is truly a dialed in boat ready to go right now.
Contact me by forum private message (click on my username and Start Conversation).
Highlights
2018 Refit
Highlights
- Gorgeous flag blue Awlgrip hull
- Custom stern seats integrated into stern pulpit
- Dodger and bimini
- Stack Pack, lazy jacks, and Tides Marine sail track
- New Harken roller furling 2023
- New Precision radial mainsail 2024
- North 135 jib in good shape
- Older asymmetric spinnaker in excellent condition with snuffer
- Standing and running rigging 2018 or newer in excellent condition
- Origo 3000 alcohol stove
- Refrigeration in icebox
- All LED interior and extierior lights
- ICom VHF
- Pioneer stereo
- Raymarine depth and speed
- Balmar alternator regulator
- Custom interior cushions are spotless and beautifully constructed
- Custom V-berth mattress
- Custom teak ceiling in V-berth
- Cockpit cushions
- Composting toilet. Old toilet and holding tank removed. Head thru hulls and seacocks replaced with bronze and remain available should future owner wish to install traditional marine toilet
- Quarterberth panel modified to provide exceptional access to engine, transmission and prop shaft seal
- Some AC outlets were not reconnected during electrical refit and are non-functional
- Dodger windows are a bit foggy
2018 Refit
- New prop strut
- Replaced rudder shaft seal packing
- New prop shaft and coupler
- Converted from 3- to 4-point motor mounts with custom brackets and new mounts
- New PSS shaft seal
- New aluminum fuel tank and Racor primary filters
- All new engine water, coolant, fuel and exhaust hoses
- New rigid exhaust pipe and mixing elbow
- Heat exchanger cleaned and pressure tested
- New custom stainless steel water lift muffler.
- Keel bolt nuts and washers replaced, tensioned and keel joint sealed with fiberglass and G-Flex epoxy
- New engine electrical panel, switches, gauges, senders and wiring
- All electrical wiring replaced and properly fused with highest quality wire, fittings, and Blue Sea Systems components, including new mast wiring, battery wiring, ACR and galvanic isolator.
- New Sterling Power battery charger
- New SmartPlug AC input
- New alternator
- New teak and holly cabin sole
- New Airmar depth and speed transducers
- New Morse throttle and shift cables
- All new Groco bronze thru hull fittings and seacock adapters/ball valves properly installed with G10 backing plates below waterline
- All new Marelon thru hull fittings above waterline
- Relocated cockpit drains to above waterline thru hulls
- Rebedded all portlights and hatches
- New plexiglass and seals in overhead hatches
- New Lewmar opening portlight in head
- New Mantus Anchor
- New chain plates and standing rigging
- All new running rigging, new blocks
- Rebedded all deck fittings with Bed-It butyl tape
- Installed larger and deeper anchor well
- G10 backing plates on all stanchions, cleats and deck hardware
- New Jabsco diaphragm bilge pump, Water Witch automatic switch and switch panel
- New Whale Gusher manual bilge pump
- New VHF mast cable and antenna and Davis wind vane
- New steaming/foredeck light and anchor light
- Universal diesel alternator bracket upgrade installed
- Small areas of side deck rot were re-cored and reinforced without disturbing non-skid
- New pressure water pump and plumbing.
- New Campbell Sailor 3-blade prop
- Rebedded seahood, reworked and upgraded traveler
- New bottom paint
- New Harken Ocean MkIV furler
- New forestay
- Relocated mast wires through glands in deck and sealed mast step hole to prevent leaks
- New engine freshwater pump
- New Trojan T-125 house bank batteries
- Deck gelcoat wet sanded, buffed and waxed
- Non-skid treated with sealant
- New Precision full batten mainsail
- New anchor roller
- Removed non-functional propane system and stove, rebuilt galley area to add more storage and installed Original 3000 alcohol stove
- New stern vents and covers
- New fuel pump
- Genoa serviced by North Sails PDX
- New composting toilet
- New Raymarine EV-100 Autopilot
