1985 Ericson 35-3 for sale
treilley
1985 Ericson 35-3 for sale. This boat is in excellent overall condition. Virtually every system has been replaced or rebuilt.
Topsides newly painted in fall of 2009. New paint has not even seen the water yet. I was waiting til spring to apply the name and hailing port. You can keep the name or change it and be the first name on the new paint. Although, there are custom embroidered towels that will come with the boat only if you keep the name "Cordelia":egrin:
This boat truly is in sail away condition. Located in Southern Maine. Additional photos here:
[http://www.tkronaboat.com/Photos/Cordelia(our Ericson 35-3)/Boat Photos(Sale)/index.html
Fuel: 40gal
Water: 85gal
Holding: 18gal
Engine: Universal M25XP
LOA: 35’6”
Beam: 11’4”
LWL: 28’10”
Draft: 6’2”
Displacement: 13,000lbs
Ballast: 5,200lbs
Electronics:
  • Standard Horizon VHF with cockpit RAM
  • HD AM/FM DVD player with remote
  • Battery charger
  • Profile tank monitor(water and holding)
  • Victron BMV-602 battery monitor
  • 12v refrigeration
  • 12v vacuum
  • Garmin 3206 chartplotter with radar
Sails
150% Dacron crosscut Genoa(2007)
Dacron full batten Main(2009)
Storm trisail
Spinaker
Other Equipment:
Dodger, bimini(and connector), dock lines, fenders(with covers), Lifesling, Jimbuoy, , 2 sets of ground tackle including 35lb Manson Supreme and Danforth anchors, boom tent, Fairclough winter cover and frame, engine spares, throughhull plugs,
New parts since 2006:
  • Hydraulic backstay adjuster
  • Transmission
  • 12v starting battery
  • 2 – 6v house batteries
  • Garmin Chartplotter
  • Exhaust riser
2007
  • Flexofold folding 2 blade prop
  • VSD fresh water pump
  • Binacle cover(sunbrella)
  • Main cover(sunbrella)
  • Teak handrails(exterior)
2008
  • Lasdrop dripless packing
  • Fairclough winter cover(mast down)
  • Hot water heater(6 gal Isotherm)
  • Standing rigging
  • Shower sprayer
  • Bilge pumps
  • Genoa(150%)
  • Furles furler
  • Garmin Radar(overlaid)
  • Folding 40” wheel
  • Toilet
  • Holding tank and hoses
  • Pump out fitting
  • Pump out pump
  • Portlights
  • Hatches
2009
  • Tank level monitoring system
  • Battery monitor
  • Ground tackle
  • Galley sink and faucet
  • Stereo/DVD player
  • Speedseal raw water pump cover
  • Main Sail
  • Lifelines
  • Line clutches
  • Primary Harken 46st winches(chrome plated bronze)
  • Interior lighting fixtures
  • Sensibulb LEDs for new fixtures
  • Teak Cockpit table
  • All Instruments(Raymarine ST60+)
  • Autopilot(Raymarine S1)
  • Rudder position sensor
  • Various running rigging
  • Shift and throttle cables
Refinshed:
  • Hull stripped to original gelcoat and sealed with barrier coat(Interlux 2000)
  • All spars stripped and repainted(2 part Urethane)
  • All interior woodwork stripped and varnished
  • Interior veneer replaced where necessary
  • Binacle refinished with new guard
  • Topsides repainted(base/clear) with Imron in 2010
Other Mods:
  • Added cleanout port to fuel tank
  • Added larger bowl to toilet
  • Created larger trash cabinet door to accommodate larger galley sink and faucet
  • Added washdown pump
  • Added clear panels to dodger for better visibility
  • Rebuilt raw water pump
Price: $62,000
Delivery options available within NE.
Maine Sail
You won't find a better boat at anywhere near that price!! This is truly a two percenter (less than 2% of the used boats are this good).
Snap it up before he comes to his senses!!!
