Dave G.
1984 E30+ Ludington, MI
Sooo..another project to squeeze in. I need to replace the prop shaft and have to drop the rudder to do that unfortunately. I have pulled the cutless bearing and still can't get the shaft out. I have done a little homework on the subject as I have not done this before, that being said I wanted to get any and all suggestions, do's, don'ts, tricks, etc. My plan is to dig a 15" hole then board and block the rudder, loosen the steering cables(counting turns), loosen the 4 clamping bolts, remove the thru bolt, and rudder should be free to drop yes/no ? Go back on the ground support the rudder remove the blocking/board and ease it down. What am I missing or need to do before I drop it ? As always thanks for your feedback.
